Anyone using this?
Anyone using this?
GM Performance Parts catalog shows (in the new 2005 catalog) that this will work on the 4L60E, 4L65E, 4L80E & 4L85E.. The web site only lists 4L60E as stated below.. Just wondering if anyone has any experience with this?
12497316 4L60E Transmission Controller
Includes wiring harness, controller, software and lap-top hook-up. Allows the use of electronically controlled transmissions in early model vehicles. Fully programmable for upshift, downshift, part throttle and wide-open shifts and shift firmness. Comes pre-programmed, just enter your rear tire diameter and rear axle ratio and go, or create your own custom shift characteristics. Originally developed by GM Racing for off road truck racing. The controller has the ability to record and graph drag race data like time, speed, shift point, engine rpm and more. Requires a throttle position sensor on carbureted applications, see instruction manual for specific parts required.
Originally Posted by Ragtop 99
Do you have a conversion project going where you are not going to use an LS1 PCM?
