HELP! Vacuum Modulation Install
Old 02-26-2005, 09:39 PM
CCut's Avatar
Default HELP! Vacuum Modulation Install
Ok so I bought a built 4l60e and it has vacuum modulation, now heres question: how do you hook up the line and what needs to be done?
TIA
Chris
Old 02-26-2005, 09:50 PM
gen 3 bu's Avatar
i have never seen a 4l60e with a vacuum port
Old 02-26-2005, 10:31 PM
Ken95Z28's Avatar
It T's in the Brake Booster Line. The "T" should have came with the vacuum modulator.
Zippinzee's Avatar
T off of the power brake line and hook your transmission line to it. The vacume modulaton for a 4l60 comes from transgo.
Old 02-26-2005, 11:21 PM
1998TA__1991RS's Avatar
what does it do
Old 02-27-2005, 12:36 PM
Black02Z71's Avatar
Originally Posted by 1998TA__1991RS
what does it do
It controls line pressure based on vacuum, instead of the pcm.
What do you set the pressures to, and how do you set it.
Old 02-27-2005, 02:15 PM
NC00Z28's Avatar
what does it do
It is supposed to bypass the electronic pressure controls to give you quicker pressure rise
Old 02-28-2005, 06:59 PM
gen 3 bu's Avatar
do you have any links and/or more info on this
Old 02-28-2005, 09:42 PM
Pontiacerator
RevGTO's Avatar
Search ... there are many threads on this.
Old 03-01-2005, 12:05 AM
Restricted User
Automatics's Avatar
The EPC solenoid (force motor) has a preset of about 170-180 psi of main line pressure at WOT in the "D" position. When using the Trans-Go modulator, and the Trans-Go main boost valve, and you install the modulator pin "as is" (no grinding), it will put out about 220-235 psi at WOT in the "D" position. This can give you a much longer 3-4 clutch life. It also allows for a much faster downshift than its computer controlled couterpart.
