hard 1-2 shifts
hard 1-2 shifts
i have a 01 gmc 5.3L 4x4 4l60. i had the HD-2 trans-go kit installed with no washers,also a vett servo.i like all the shifts except the 1-2 it hits harder then i thought it would.ex. at 3\8 throttle it chirps the 1-2,all the rest of the shifts are perfect.if i remove the servo would this soffen the 1-2 without affecting the other shifts?also with the shift-kit when i hall (8000lbs trailer) should i still use the tow- hall?thanks for any info.
