YANK'S th400 install kit on SALE
WE have on sale till march 26th or 98-02 f-body TH400 basic install kit :
this kit includes
1, th400 nonlock up race converter in your choice or size and stall speed
2, transmission crossmember for th400 without T/A mount pn#YC102
3, speed sensor kit for a-4 conversion
4, transmission mount th400
5, bolt kit
6, shipping in the USA
Total package value of $1253.00
a savings of $ 203.00
for a special price of $1050.00
you can upgrade to the torque arm mount
YC103 for only an extra $75.00
http://www.converter.cc/drivetrain.htm
or CALL US 775 826 9955
this kit includes
5, bolt kit
Originally Posted by Slow Z28
What if I needed it without the tranny crossmember? And I have an M6 so how does the speedo sensor stuff work out? Thirdly, any specials on same thing but WITH a trans? Reverse manual vb and a TB.
Chris
Chris
as we have all the parts that you will need
Mike Or Dave 775 826 9955
good job yank! thats what alot of us need... dose this come with the dipstick tube? and when switching over from a 4L60e what needs to be done to the drive shaft?
thanks
scott
thanks
scott
thanks
scott
thanks
scott
you have a few choices on that, and we use a LOCAR unit that is 42"l ong to allow removal of the trans with out fighting the dipstick bolts
we also use a new drive shaft (steel) and have the 1350 or stock joint in the rear, that is not in the kit price for an extra $280.00 (stock) to $340.00 (1350) u-joints
or you can get one made that is approx 3 3/4" longer than stock depending on the yoke you use, at a local driveline shop
this kit includes
5, bolt kit
this kit includes
5, bolt kit
Also what size (8" or 10"?) and what stall (3500-4000?) converter would you recommend for a 575rwhp (probably 650rwtq) nitrous car?
Thanks
Ross
Originally Posted by bad2000ss
Yank, does your crossmember work for a short or long tailshaft TH400, or does the length not have anything to do with the mounting location? I am going to convert from a T56, is there anything you guys offer to make the speedo work?
Thanks
Ross
Thanks
Ross
we have made a custom reluctor ring that has the m-6 tooth count on it and a special mag. pickup assy that we have made for the TH400 for use with the m-6 also this will allow the speedo to work as normal. price is $230.00
on the converter 4000 stall in 8" will be faster (its lighter in weight) if you are a foot brake racer, and if a trans/brake is in the plans a 10" 4000 is the way to go for you
Our crossmember has a slot in the mounting plate for the trans mount and will work with the longer tail housing
10, 400, 4000, adapter, converter, forsale, installation, installing, ls1, sale, speedometer, th400, transmission, turbo, yank, yanks
