flywheel bolts make leak?
Old 03-22-2005, 03:00 PM
Randyman's Avatar
Default flywheel bolts make leak?
i was curious about something. I bought my S10 blazer knowing it had a transmission leak inbetween the TC and the tranny. Thinking it wouldnt be that hard to fix, we have had many problems with it. I changed the seals, put a brand new TC and even a new Transmission and changed the seals again 2 more times. When we put the new tranny up in it for the first 2 days it was fine and not leaking but the entire blazer vibrated like crazy. On the fly wheel the three bolts that are used to bolt the TC to it 1 of them has a larger head on it and i was wondering if that would cause the wheel to turn lopsided maybe causing the tranny to leak? if not maybe the rear drive shaft?
Old 03-24-2005, 04:39 PM
john kilgore's Avatar
Default bolts
sounds like only one bolt was working. you may have two bolts that have a 9/16 head and one with 15mm. if l'm not mistaking s10 tc were all metric.
