Trans go downshifting?
Just had my Trans go shift kit installed yesterday and I noticed when I hammered down while in 3, the car downshifted automatically. I thought the shift kit would not allow this while in 2 or 3.....only in D (drive) should the car down shift.....well at least this is what I thought. Anyone with a shift kit on thier 4l60e knows what is suppose to happen?
Originally Posted by nitenshinarmor
So, is down shifting in 3rd normal or not? Or does this need to be changed in the car's program to prevent downshifting in 2 and 3.
My car has the transgo kit and all hell breaks loose when I stomp the gas and it downshifts. I would consider that a good thing and the next step would be to get tires for better traction.
Why would you want to stomp the gas and have it just slowly pick up speed?
I'd rather have it drop down and pin your head back in the seat.
Originally Posted by jxaxsxoxn
Don't you think the car will feel slower if it doesn't downshift?
However, at the track, I found shifting from 2nd to 3rd at wot when I like doesn't happen
I had just thought part of the meaning of "shift kit" meant you would be able to shift the car whenever you desire.
If you want to upshift and downshift at your command you need a full manual shift kit to convert the valve body.
