Who has problems or vibrations after a torque converter install?
Iam looking to install my torque converter into my 98 trans am and iam looking to see if anyone here had any major problems after installing the torque converter? like vibrations etc? if so what did find out the problem was? did you solve it?
When I got my Vig 2800 installed there was a combination of different things going on. First the only vibration I remember was that it reved more and the exhaust was louder. I thought I had more vibrations, but everything turned out to be normal.
Still working on my problem, the shop balanced the converter again, internally and externallly. Now I'm going back to a stock converter to see if the vibration goes away, then I'll narrow the problem down from there. I would recommend going with a good shop and a good "KNOWN" converter shop.
what converter are you using? whats the problem with your car? what kind of vibrations are you getting?
