My M6 to TH350 swap with pics
Old 05-04-2005, 11:00 PM
SUX2BU's Avatar
Default My M6 to TH350 swap with pics
here's some pics of the tranny cross member i made for my TH350. I didn't wanna weld a plate to my M6 cross member so i made this one out of 1/4 thick steel. it was 4 inches wide, but that seemed way too heavy and big so i sliced it down the middle and made two 2 inch crossmembers. you can alsio see how i mounted up my B&M pro ratchet shiffter.The entire swap was about $2,565, i sold my Ram clutch and Mcleod master for $400 and my entire M6 set up for $1,000. so i really spent about $1,165 out of pocket. But i wanted all the good stuff the first time so i'll be set.
TH350 fyully built w/transbrake and dyno test $1,100
extra 3 quart aluminum B&M finned pan $110
B&M Pro Ratchet shifter $170
Lokar 36" dipstick $75
used 98 A4 flexplate $45
4600 8" non lock up converter $915
big *** B&M cooler $85
tranny temp gauge $45
metal cooler lines (i bent myself) and fittings $20
Quick Reply: My M6 to TH350 swap with pics
