converter accessories 5 basic questions!!!
im about to install a converter (3500 stall) for a future ls6 headed and fm14 camed car .....What mods should i do along with the torque converter to help out the tranny..spifically:
1: for this power range (500-550 bhp) is there a reason for a upgraded flex plate?
2: synthetic fluid or regular atf?
3: deep pan worth it....?
4: if i got my tranny tuned with hp tuners (shifts great as of now) should i also do a shift kit or is this a waste of time?
5: what seals should i replace while im in there pan gasket, pump seal..?
the car is a 2002 t\a with boltons 20k miles weekend driven most of the miles are hard miles this is not a hwy cruser the car is strictly taken out for amusemnt...see sig for actual current mods
thanks,
john
thanks,
john
1. Yes, the 2002 flexplates are weak and get the TCI SFI Flexplate
2. Stay with Dexron III and no synthetic. It cause slippage.
3. No, The external cooler for better for cooling. If you want a drain plug, get the kit for NAPA for $6.
4. Do either programming or a shift kit. Do not both.
5. The front pump seal and tailshaft seal. If you suspect pump leakage then, do the pump oring.
LS1 Tech Administrator
What he said. As far as fluid goes, I've had lots of luck mixing Type F fluid with the Dextron III. Makes the clutches grippier. Synthetics make them slipperier...not good.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
i might just do a cooler and temp gauge.. the shops i spoke with said the flex plate is fine for a head\cam car .. the jury is still out on the fluid choice im gonna call tci on moday for a little more reserach
what can happen if the flex plate cracks do they explode ???? i mean am i replacing it for safety? performance? or just beacouse im already in there and its a good time to do it???....(please explain, i can already feel the "well all three" reply comming)
thanks,
john
thanks,
john
"All Motor 9 Second club member"
The flex plates DO crack (I'm speaking from experience), but I caught mine before it exploded as many others have experienced. It will cost a lot more if you wait and find out the hard way. I have pics if you like.
Yes, it's for safety, they do crack and come apart and your already there so that's the best time to do it.
I regret not doing it 5 months ago when I had the tranny out, but I'm doing it now.
