throttle sensor
Old 05-10-2005, 08:29 AM
1superchevy's Avatar
Angry throttle sensor
Can a bad one cause the transmission to run funny because i just had it rebuilt and not at part throttle it doesnt want to go into gear the engine just revs up and down until i let off and then it catches.
Old 05-10-2005, 11:54 AM
strokedls1's Avatar
Sounds like either you don't have enough fluid in the trans or it wasn't built correctly. I doubt it is the tps. You can read the tps on tuning software scanners or autotap, efilive.
