whats going on??
Old 05-13-2005, 11:01 PM
Jpr5690's Avatar
Default whats going on??
ok OCCASIONALLY (2 times in the last 2 months) from a hwy roll the tranny has banged the rev limiter but when i go for a full run and every other time it works great could this be some sort of a tuneing issue or is my tranny heading south?
Old 05-13-2005, 11:02 PM
Jpr5690's Avatar
o yea its not like its toping out a gear and banging it it just seems like it you slam it down and its in netural for a seccond is this a 4-2 shift problem??
Old 05-14-2005, 09:10 PM
Jpr5690's Avatar
comon any guesses?
Old 05-14-2005, 10:12 PM
blkZ28spt's Avatar
I don't remember exactly what it was (I"m not very tranny educated, but have read of this before) but my guess is that "tranny going south" will be the result of the diagnosis.
Old 05-14-2005, 10:32 PM
ChevyZ28Thunder's Avatar
I agree that is the first signs of your tranny going bad.
Old 05-15-2005, 03:11 PM
Jpr5690's Avatar
ahhh! dont tell me this... just lie to me and say its just fine! well the verter is getting droped friday so thell havethe pan dropped hopefully anything shitty can be found then
Old 05-15-2005, 03:58 PM
Stroker 1500's Avatar
from everything i have read that is a problem due to a worn clutch pack
Old 05-15-2005, 09:50 PM
Jpr5690's Avatar
the fluid smells fine to me... but it did it again tonight!
Old 05-15-2005, 10:17 PM
Jpr5690's Avatar
ok its when im crusing in 4th and i slam it down say from a 70 roll the car seems to drop in to netural for a seccond before shifting ie: you slam it down it immediately bangs the revlimiter then it shifts! it does is infrequently ...
ALSO I HAD A TORQUE CONVERTER INSTALL PLANNED FOR FRIDAY SHOULD I HOLD OFF ON THIS .. COULD THIS DAMAGE THE CONVERTER IF THE TRANNY IS GOING?
Old 05-16-2005, 04:43 PM
Jpr5690's Avatar
the locals are tring to say its either a converter clutch problem or a sprag problem
