TCI ssf 3500
Old 06-26-2005, 12:14 AM
formulajunky's Avatar
Default TCI ssf 3500
My only question is simple. I haven't installed this yet, Just wonding sense i just can't wait to find out. Is on stock brakes and BF Dr how high am I going to be able to launch. Stock engine to only few free mods and I do spray but That shouldn't be an issue here. I just love Launching and would like to know how This setup works for you guys in yours I'll have mine in about a week in my car. Thanks
Old 06-26-2005, 06:21 AM
ls_101's Avatar
3100-3200 street tires, with new brake pads around 3400 on dr's
Old 06-26-2005, 07:58 PM
Thank good that is about what i wanted and the all around "Flash" of the converter should be good for what?.2-.3 tenths maybe with my BF Dr
Old 06-26-2005, 09:14 PM
Jeremiah's Avatar
Picked up .5 tenths with SSF 3500 in my car, freind also had exact same results.
Old 06-27-2005, 01:41 AM
Scotty-Z's Avatar
Common results are .5 seconds with most stalls that size. With some good drag radials such as the ones you have, I've seen cars lose up to .7 or .8. Can't wait to buy my stall!
Old 06-27-2005, 06:03 AM
ls_101's Avatar
.6 gain with mine, i know it had more in it though
Old 06-27-2005, 09:02 AM
Z'mnypit's Avatar
How do you leave at 3100-3200? I have the ssf3500 & cant stall it past 2200 on et streets.
Old 06-27-2005, 09:03 AM
EDALVA21's Avatar
Location: In the big city of Houston and big state of Texas.
Did you'll get the cars tuned before you'll saw those results?
Old 06-27-2005, 09:04 AM
CHRISPY's Avatar
My car has never been on a dyno. I did do shiftpoint changes, shift adaption changes etc.
Old 06-27-2005, 09:55 AM
EDALVA21's Avatar
My car doesnt seem to hook and when stopped at a stop light the rpms goes anywhere from 500 to 700 up and down, up and down. Thats why I was wondering if I had to tune the car for it.
Old 06-27-2005, 03:04 PM
Well I didn't expect you would all say about 1/2 sec That would be great Might just put me at 13.00 That would be cool. Anyways thanks for The ideas i'll post up When i get it in hoply before I go to the Track on the 8Th Now all i need is For it to get to my house so i can put it in
Old 06-28-2005, 07:05 PM
ls_101's Avatar
honestly i dont know, i stall up and it launches hard, 2200 on et streets wow, u might want to check the trans and convo, also make sure ur brake pads are like new, i have brand new pads and rotors all around and front calipers as well, u need reall good brakes, i also have a alum driveshaft
Old 06-28-2005, 09:29 PM
blkZ28spt's Avatar
I don't think I could stall my SSF3500 to 3k or above. Actually, my now restalled SSF4000 spins the nittos over not too far above 3000. I launch from ~2900 at the track thus far. (SSF4000)
Old 06-28-2005, 11:02 PM
1QuickT-A's Avatar
Most guys I know will only bring the rpms up to like 1500 or so.. Even if they have a 3800stall. That way it gets the slack out of the suspension and rear end and when you come off the brake and floor it the converter will flash up high and give you that extra "kick" out of the hole..
Old 06-28-2005, 11:11 PM
blkZ28spt's Avatar
Ask them if they've tried getting the revs higher, and if not tell them they should try it. I 60' better getting them close to 3k. (4k stall)
