tH400 GUYS IN HERE!!
Old 07-06-2005, 04:56 PM
NickcZ28's Avatar
Default tH400 GUYS IN HERE!!
What gears are you guys runnin, What is the best setup for Street /strip???
I have 4.10's, and a 4000 stall?????
Also on stock 2455016's tires
Old 07-07-2005, 10:24 AM
NickcZ28's Avatar
cMON!!!!!ANYONE??
Old 07-07-2005, 10:38 AM
gator's 99TA's Avatar
good god, do you realize how many rpms that is at 60 mph? have you thought tha out? and why a th400 with such a tiny stock tire? no 245/50 is gonna hold up to any decent sized convertor in a TH400.
unless you turn a LOT of rpm, you will run out of gearing.
Old 07-07-2005, 10:48 AM
NickcZ28's Avatar
I can go a steady 55 on the freeway at 3000
Old 07-07-2005, 11:17 AM
white_ta's Avatar
I ran a 4500 stall in my TH400 with reverse manual valve body and trans-brake. I had 4.10 gears and 26x11.5 MT ET streets. It was ok on the street, but blew the tires off easy. I never took it to the track because I'm building a tube chassis car out of it. My car also dynoed 720 h.p. though.
Old 07-07-2005, 09:35 PM
theblur98ss's Avatar
I have a TH400 and Yank pt4000 converter. I used to have 4.30's and it would break the tires loose right now. It was ruthless on the highway though. I opted to change to 3.50's. The car is obviously less touquey now but is livable on the highway.
Old 07-08-2005, 10:53 AM
john kilgore's Avatar
Default gears
there are custom planet sets to give you the throttle response you lost when you moved your rear gear up. the two ratios are 11% deeper and 21% deeper.
