4l60e 94 to 95 tranny swap
Old 07-17-2005, 12:10 AM
farsighted770's Avatar
Default 4l60e 94 to 95 tranny swap
i have a 95 firebird formula with a 4l60e tranny in it, that blew up and the guy who did the last rebuild on it is a tool, so long story short, i had to buy another one. this one came out of a 94, so i want to know how to put this one in, someone told me change a wire for the torque converter lock up, but i need some in depth details on this, and on anything else i may need, i appreciate any and all help on this, thanks guys!
Old 07-17-2005, 12:12 AM
http://www.autozone.com/servlet/UiB...23d801ee930.jsp
if i do need to run a torque converter lockup wire from the 94 harness to the 95 pcm which wire do i run to where... i cant see the difference. page three of three on both of these 5.7ltr p engine code diagrams has this system wired almost identically, same everything.
the only torque converter control setup i see in there is the tan and black wire (11) and thats the same on both... no seperate control for the lockup on the torque converter, like i thought i needed for the swap...
Old 07-17-2005, 02:04 AM
update, 94 wiring diagram also does not match the wiring harness i have for the 94 tranny... i am missing a sensor ground cable(black... i would think that it should ground right on the tranny, afterall the block is grounded but :dunno, and i have two extra cables(pink/black, and purple)
could this be more annoying?
Old 07-18-2005, 01:58 AM
ttt, i could use a lil help guys...
Old 07-19-2005, 03:40 PM
NikonDrgn's Avatar
bump for ron, hes a good guy, we have been tryin to figure this out for a while, and shops cost a lot of money, any help you guys could throw our way would be great
Old 07-19-2005, 06:00 PM
Rock-On's Avatar
Default hey
listen up ..it goes like this..93-94(12pin) interchange...95 (13pin)pwm stand alone...96(13pin) pwm ec3 to present interchange....there is sooooooo much differant from the two it' would be a big waste of time to go into it. Basicly this is the way it is ...hope this helps..Dave
Old 07-20-2005, 05:54 PM
transman618's Avatar
I agree with Dave. 94 is only interchangable with 93. 95's are PWM and will not work with the earlier version of the 4L60E. Sorry, but you need to find either a 94 or a 93.
transman
Old 07-21-2005, 05:35 PM
lisa33's Avatar
If you get wiring schemas for the both trannys it shouldnt be any big trouble to get this to work, you have to fool the 95pcm that its hooked up to a PWM tranny, all it takes is a 20-30ohms 20w resistor hooked up between the pink (12v+) and the brown (PWM ground) in the wiring harnes outside the tranny...
And yes that works, im running a 4l80e -94 in oure -95 z28 , I use the PWM to activate the TC lockup (94-4l80e use PWM but no TCC and 3->2 solenoid) and have a resistor to simulate the lockup (TCC) solenoid,
the shift solenoids was another storry but that isnt a problem for you...
http://home.koping.net/u3243a/vinter...5/DSC02428.JPG
(and yes, 4l80e wired to a OBD1 camaro shouldnt work acourding to others )
ake
Quick Reply: 4l60e 94 to 95 tranny swap
