what the best rebuild kit for 4l60e ?
Old 07-21-2005, 06:58 PM
ss2002's Avatar
Default what the best rebuild kit for 4l60e ?
I am found this one :
4L60E/LS1 Rebuild Kit Pro Street w/vacuum modulator #176
"Complete description of the parts in the rebuild kit"
"Front pump"
Seal retainer
Late design seal
10-vane rotor w/vanes & slide assembly (higher volume than 13-vane setup)
Trans-Go steel rings & priming spring (over 5,500 rpm)
New replacement stator support
HD steel sleeve, overrun piston, & Cryoed forward piston for the input drum is included.
"Clutches, Steels And Pressure Plates"
4 Borg-Warner reverse/input clutches .068
4 Reverse/input "low drag" Turbulator steels .078
1 .078 spacer plate with reverse wave (eliminates the belleville spring)
5 Borg-Warner forward clutches .070
5 Forward steels .090
2 Borg-Warner overrun clutches .078
9 Borg-Warner Hi-Energy 3-4 clutches .065
3 3-4 steels Kolene .060
5 3-4 Steels Kolene .076
2 3-4 pressure plates .128
5 Borg-Warner low/reverse clutches .087
5 Low/reverse "low drag" Turbulator steels .068
1 3-4 apply ring 5-tabs
1 .062" 3-4 snap ring
"Other"
Sealed Power Beast sunshell
OEM 29 element input sprag (late design)
Borg-Warner low/reverse roller assembly (late design)
Vamac 3 lip rear seal (prelubed)
Transtech paper & rubber (gasket) kit
Transmission filter (OEM)
Converter solenoid filter
Bushings (latest updates, including Teflon front pump & extension)
Thrust washer kit
Sealing ring kit
HD Bearing kit (Timken)
Borg-Warner Hi-Energy 2-4 band
Trans-Go Performance Shift kit w/accumulation for nice part throttle shifts
Trans-Go vacuum modulator
and this one :
TCI-378950
Brand: TCI Automotive
Product Line: TCI Pro Super Transmission Overhaul Kits
Transmission Bands Included: Yes
Transmission Clutches Included: Yes
Transmission Gaskets Included: Yes
Transmission Seals Included: Yes
Transmission Filter Included: Yes
Shift Kit Included: Yes
Quantity: Sold as a kit.
Notes: Includes a drain plug.
Automatic Transmission Rebuild Kit, Pro Super, 4L60E, Kit
Check to make sure this part fits your application
Rebuild your transmission before it's too late.
TCI's Pro Super transmission overhaul kits have everything you need to do a complete rebuild. In fact, these kits contain all of the same components as TCI's famous Streetfighter transmissions!
Kits include:
* Gasket and seal kit
* High-quality clutches
* Steels
* Forward bands
* Adjustable modulator
* High-volume filter
* Drain plug kit
* Trans-Scat valve body modifications
I want to know what is the best company and any one use 4L60E/LS1 Rebuild Kit Pro Street w/vacuum modulator #176 tel me how is it now with him.
and if you know any very good another Rebuild Kit .
Thank you,
I am using my car daily
Old 07-21-2005, 07:12 PM
jxaxsxoxn's Avatar
I'd go with ProBuilt. Simply because he has helped me here and he knows I have never bought anything from him. (yet)
I'd buy from the better person, not parts house or general performance parts supplier who knows nothing about what they're selling.
The following users liked this post:
BENR (02-08-2023)
Old 07-21-2005, 07:14 PM
cablebandit's Avatar
I dunno about the parts but that's only half the game. i think a tranny like mine and one somebody blows up with 450hp prolly have the same parts.....it's the experience with these trannys that makes the difference. The good builders have all kind of little tricks they use to get pressure at certain times....quick shifting..etc.
Old 07-28-2005, 05:35 PM
spec_j's Avatar
the top one is the one i was going to get but im going with a Street Evil Stage1 4L60E Transmission only $1200
Quick Reply: what the best rebuild kit for 4l60e ?
