$505 for converter, gears, and cooler install, sound right?
Old 07-27-2005, 01:37 PM
TA4U2NV's Avatar
Default $505 for converter, gears, and cooler install, sound right?
Trying to get some info on installation prices, not saying they're ripping me off, but i'm just searching around to see if the prices match.
$225-250 for converter install
$200 for gear install
1 hr labor/($55) for cooler instal
$505 max, does that sound right for all this stuff installed?l
Old 07-27-2005, 02:01 PM
Scotty-Z's Avatar
Hmm, you might be able to get it a bit cheaper than that, but as you know, every place can vary. I normally hear around 250 for the converter and tranny cooler installed together. You can do the tranny cooler yourself though and save that money like I'm doing.
It looks to be around the neighborhood of prices I hear.
Old 07-27-2005, 02:41 PM
00firebird's Avatar
damn thats one hell of a steal if u ask me , ive been quoted 500 serveral times just for gears alone.
Old 07-27-2005, 03:05 PM
Scotty-Z's Avatar
That's just a joke right there.
Old 07-27-2005, 03:15 PM
onyx_rock's Avatar
thats a good deal. I paid 800 for installation of TC, cooler, gears and fluids. This was from the best driveline shop in my area. Here in Pittsburgh we dont have alot of reputable shops so I didnt shop around but went with the best.
Old 07-27-2005, 03:16 PM
Sold The Fun Stuff :(
josh99ta's Avatar
Properly setup gear installs, where the mechanic takes his time and makes SURE its right, usually go for $250-300 around here. Converter installs are around the same, and that includes a trans cooler. I'd say thats a good deal as long as the mechanic doing the gears stands behind his work.
Old 07-27-2005, 03:18 PM
2001NBMZ28's Avatar
I paid $350 locally for just the TC install, did the cooler myself. I'd go for it.
Old 07-27-2005, 03:23 PM
TA4U2NV's Avatar
Alright thanks guys! All I needed to know!
Old 07-27-2005, 10:28 PM
Strahley's Avatar
Aww install the cooler yourself man. It didn't take me but maybe 30 minutes to install mine, and that also included the time it took to make a custom heat shield to fit with my headers & the new tranny. It's very simple, spend that $55 on gas
Old 07-27-2005, 10:42 PM
94greencamaro's Avatar
I got my gm 3.42 gears in for $480 including parts
Old 07-29-2005, 11:04 AM
zman1969's Avatar
Default gears install
labot time for ring and opinion install is under 5 hours so shops charging 500$ is over 100$ an hour , in my book thats spendy! 300$ sounds more like it
Old 07-29-2005, 12:44 PM
TA4U2NV's Avatar
Anyone got a write-up on the tranny cooler install? I wouldn't mind doing it myself and saving some money!
Old 07-29-2005, 12:47 PM
My'98-Z's Avatar
Looks good to me.....paid 225 to install gears....gonna do the verter and cooler myself
Old 07-30-2005, 12:41 AM
Strahley's Avatar
Get the cooler in front of the radiator, get it secured, make sure the in & out hoses are clamped secure, run the lines to the tranny (make sure to shield the lines from the heat from headers), secure the clamps leading into the tranny, and make sure there aren't any moving parts (mainly suspension) that will pinch your hoses. That's all there really is
I ran mine through the K-member on the passenger side, custom made a heat shield (my lines run right under the passenger side's header), tucked everything up, and used heat reflective tape on both hoses from start to finish. It's really a simple install, you don't have to drill any holes or anything. Mine took about 30 minutes to mount, clamp, tape, and make a custom heat shield, and that was with me working slow in the 105 degree heat. I'd go get some pics but it's a little dark outside
Old 07-30-2005, 08:53 AM
jmilz28's Avatar
As long as it's a good shop/tech, that's a VERY fair price. VERY!
