Shift Kit or Tuning
Old 08-08-2005, 10:15 PM
Kiss_My_99SS's Avatar
Default Shift Kit or Tuning
I just installed a TCI 3500 and the transmission shifts a lot softer. Which should I do: shift kit or tuning?
Old 08-08-2005, 10:42 PM
Scotty-Z's Avatar
I'd say shift kit because it has parts that achieve things that tuning alone can't.
Old 08-08-2005, 10:54 PM
koolaid_kid's Avatar
I would recommend the TransGo shift kit. My car went from soft (read slipping) shifts to leaving rubber on the asphalt on the 1-2 shifts. And the shifts, although firm, are still quite decent (not harsh).
My tuner agreed, it was the better choice.
Old 08-08-2005, 11:03 PM
The Sad's Avatar
I like my tuning. Shifts real strong from 1-2 (read barks tires) and pretty good going into 3rd.
Old 08-08-2005, 11:25 PM
Z28_Ninja's Avatar
i would say to do the tune now, and to do the shift kit well you have the tranny built (if you are going to have it built). with a tune and a few bolt ons (no converter) i was spinning the tires on the 1-2 shift with nittos drag radials. there is really only so hard you can have a tranny shift before you start to do real damge and a good tune can easily achive that. plus the tune will give you other benifits besides firmer shifting. just my .02 though.
Old 08-09-2005, 12:51 AM
vMaster0fPuppets's Avatar
both but have the tuning not harshin the shifts leave that to the shitftkit
Old 08-09-2005, 09:56 AM
What does it cost to get a shift kit installed?
Old 08-09-2005, 11:04 AM
Scotty-Z's Avatar
I think I would agree with this, but let me rephrase it:
"Get the tune and the shift kit, but don't let the tuner firm up your shifts. Leave that to the shift kit. If you get a shift kit AND have the tuner raise line pressure too much for your tranny, you'll fry it in no time."
I think some of the big transmission guys on the site have all agreed that the way to do it is the shift kit. A tune can only raise line pressure, and even then, it can't do it for wide-open throttle. A shift kit can do this, plus it lengthens the life of your tranny.
Once again: Go for the shift kit.
Old 08-09-2005, 11:16 AM
HAWK#549's Avatar
shift kit.....i have a Trans Go and i couldnt be happier, and it was 150 installed.
Old 08-09-2005, 10:15 PM
MiaSSmaro98's Avatar
shift kit and remove tm if tranny is strong. if weak or alot of miles leave it alone.so beside line pressure and tm wat else can u tunein the tranny?
