th-400 experts in here
I just installed a th-400, took out the M6 and I have a question. The torque converter is about a 1/4 in away from the flexplate. Is this normal? Should I just push the tq toward the flexplate to eliminate the gap, or is there a spacer I need to get. The nipple on the torque is already centered and in the flexplate, so there is no problem there. Any help would be appiciated.
Do a google search for rossler transmission. Their site has a detailed but simple procedure for adding spacers to set proper clearance. Make sure to check the converter to crank pilot hole engagement.
