help i dont knwo what im doing rong
hey 99 ss 3800vig ltheaders catback 373
i got teh stall in a while ago, i got a tune and all,,, but im still only winning by haf a car against stock ls1s,, and at the track i only ran 13.8,,, i dont know whats up??? any ideas or Qs im clueless
um i went here very humid and muggy no sun, looks lie its guna rain weather,,,, i have firehawk tires,,, my 60ft sucked like 2.238 104.13 13.87,,, im hoping it was the tires i meen at times i dont even hear my tires squeel maBey ther getting bald
those 3.73'z and that stall (wats you str? i think its up in th 2.0ish)...
you'll need a good set of drag radials at least. With et streets, you'll see where the gains for sure. I would also, if you havent already, get a set of LCA's at least, the wheel hop will kill that stock 10 bolt.
good luck!!
good luck!!
Like some people have said tires are a big issue. You are not getting a good jump out of the hole. If you ran some ET streets you will be getting way better times atlest low 13s to high 12s. When I use to go to the track with street tires and the stall i just would spin the tires like crazy off the line and one time the car did fishtails down the track our cars just dont work as well on street tires thats why i only run with some type of sticky tire.
You need to learn to launch without excess wheelspin.
And/or get sticky tires to get a really good launch. With nothing but headers, duals, lid, 3500 stall and ET streets (no tune) I cut 1.72-1.75 60's. A 2.23 kinda, well, SUCKS. Stock that wouldn't be good, let alone with a converter. Try drag radials or ET streets, removing as much weight as possible and pull the front sway bar.
yuh all that helps,, i just order relocations brakets for the LCA,, that will be good ill get some new tires o yeaaaaaa and ima start saving for a built stage 4 4l60e trans just in case
thanks guys,, now if i were to build my trans what shood i get a stage 3 or something i dunno???
