th-400
Old 09-07-2005, 11:16 PM
1999TransamWs6's Avatar
Default th-400
Hey,
I just got a th-400 from rossler transmissions with a trans brake and a speed sensor. Anybody know if the wireing for the speed sensor matters when splicing it into the stock speed sensor? also for the trans brake i have a hurst shift **** w/switch and running one wire from **** to power then one to trans brake and from trans brake to a ground? i think this is correct but if im wrong help would be appreciated. Thanks
-Joe
Old 09-08-2005, 12:43 PM
02Z28's Avatar
How much did the tranny end up costing you? I'm looking at buying one too. What size stall are you going to be using?
Old 09-08-2005, 02:25 PM
its about a 4000 stall and the tranny with brake/ speed sensor was 1620 shipped and my converter is a ptc it was about 450 with balloning plates and made for the ls1 flywheel i cant wait till its on the road but it will be like another month because of backordered parts
Old 09-08-2005, 02:33 PM
kp
kp's Avatar
Trans brake wiring is correct, doesnt matter which way you hook up the VSS.
Old 09-08-2005, 04:40 PM
thanks one more question i noticed a grey bable going to stock shifter and it goes to steering column is this need in anyway because there is nowheren on my hurst shifter for this cable thanks
Old 09-08-2005, 04:46 PM
Sandmann120's Avatar
Just leave that cable off. I did on mine.
Old 09-08-2005, 04:47 PM
Thanks for all the help guys. hopefully it is up and running soon!!
Old 09-08-2005, 06:33 PM
02Z28's Avatar
Good luck with the install. What shifter will you be using? Also where did you get the converter?
Old 09-08-2005, 08:08 PM
using a hurst quarter stick and a ptc 3800 stall converter. another question how do i wire up neutral safety and which wires to use?
Old 09-09-2005, 02:27 AM
Jimmy P's Avatar
Ya, were did you get the PTC converter?
Old 09-09-2005, 08:47 AM
I got it directly from them www.ptcrace.com They are supposedly very good and cheap my buddy runs one in his 2500 HP mustang obviously a better converter then mine but even his was $900 with everything
