TH400? how to hook up speedometer?
Old 09-15-2005, 09:13 AM
BKHAWK1's Avatar
Default TH400? how to hook up speedometer?
I have the parts installed allready, I just need to know where to put the two wires. The car had the A4 in it. The plug in for the stock is not labeled so if you have any idea which whole to stick the wires into will help. Or if i should splice anything.
Thanks ahead of time
Old 09-15-2005, 01:00 PM
ApacheDrill's Avatar
Do you already have a speedo? In order to use the speedometer you need to run a speedo off the tail of the tranny or tap into one of the ABS sensors ( this will delete your ABS) do a search there are a few good write ups on this. I have a extra speedo if you decide to go in that direction, send me a PM and let me know..Jim
Old 09-15-2005, 03:34 PM
BKHAWK1's Avatar
I am using the stock speedo. i had to put a reluctor ring in the TH400. i have the tranny stuff all pluged up. i just need to know which wires to splice to hook these two wires off the tranny to. I will look at the search stuff and see what i can find. Thanks for the help.
Quick Reply: TH400? how to hook up speedometer?
