Launching An Auto
i think you need to try different methods with your car at the track. i was able to torque mine up to ~2k at the line, but when it launched it jumped out and like flatlined for about a second before it picked up again. i've found that if i tq it up to ~900 rpm and flash it, it will illicit better 60' times. this is on a stock converter of course. i think it just depends on the car. my buddy has a car similar to mine, and i likes to be torqued up at launch...i think it depends on the car.
i raced some guy 2 days ago, heated up my nittos pretty well, got at the light.. stalled it up to 2200 and then when the light turned i gave it like 80/90 percent throttle for the first couple milliseconds just to ensure the best traction then i just mushed it on the floor. i have never been to the track but i swear to you i think i got like a 1.5 60 foot time it was awesome! 3800 stall w/ 3.73s here though
At the track I've experimented around. I stalled right up to the point of the back tires spinning, stalled up to 1000 rpms, launched off idle. To date my best was 2.01 60 ft. launching off idle w/ stock converter and BFG drags
Definitley want better
1 Post
Be careful about this! Here is why: I have been launching at the light at 2500 RPMs and I just screwed up my transmission! Many people have said that I launched too high so it burned it up! I would recommend doing it at maybe between 1500-2000 and see where that gets ya! Because I have given it hard launches time after time, now I get to save up for a new tranny!
I have a Vig 3800 Stall in a stock tranny, 3.42 gear brake torque till about 2500 RPM and pulling consistent 1.7 60's...ll I am afraid to go much higher or put the slicks on cause I am on the stock 10 bolt.
My car has a vig 3200 with MTDR's and I launch at 2,800. This is a stock sup. car it cuts 1.6's. Street tire is idle to get a 2.1. If you have a stock rear beware of wheel hop, it is a rear breaker.
Before my stall, my car liked between 900-1200 RPMs, and matted on the green. Anything above I would get some spin, followed by a small bog. I' ve tried stalling to where the tires are breaking loose at the yellow and blew the tires off at the green. The best I pulled, on a OEM converter, was like a 2.0X on 335 Dunlops. Not good. My brother has a 2.73 car, and he pretty much matts it for the green and has pulled 1.9Xs a couple times on 315 GSD3s. He had pulled some good 2.0Xs on the OEM RSAs too. He has some suspension, and basic bolt-ons. Track prep', suspension prep', and a bunch of factors will determine what you get, and how to drive. You just have to experiment.
2.73 rear, BFG's and a Yank 3800.. i brake stall to 3100-3300 rpms and get high 1.6 60's.. granted I havent had any time to run it. only chassis/suspension mod was subframe connectors. testing out some LCAs tonight
