4L80E hold 1,000+ rwhp?
Would a built up 4L80E hold a 588 cube big block with twin turbos? Don't know what the hp will be yet but for sure well over 1,000 rwhp? It will be street only daily driver.
Philip S.
Shouldn't be a problem. I run a Rossler 80 in my Collectors Edition. No problem with what I'm throwing at it and Rossler said I'm not even working hard yet. Cars race weight is 3860 lbs.
Good luck.
Good luck.
If your only using it for the street only why do the turbos? My friend has a similar displacement motor that make 840 flywheel hp, and runs low 9's on motor. That is a race car only and would be a handfull to drive on the street.
Probably going to go for the 4L80E but I also saw built up Allison tranny's at www.transmissioncenter.net
