Automatic vs 6 speed Standard
Old 09-25-2005, 01:30 AM
frkkevin's Avatar
Default Automatic vs 6 speed Standard
I do not currently own an F-body camaro or firebird but I am going to purchase one. I have two cars in which I have narrowed my search down too. Both are 1999 Camaro Z-28 T-tops. One has 27k miles and is an automatic. The other has 71k miles and is a fully loaded 6 speed standard. What are the benefits of the 6 speed? The fully loaded camaro is only 500 more than the other so the price is nearly the same. Which of the two would you suggest?
Old 09-25-2005, 01:32 AM
spy2520's Avatar
i'd take the one with low mileage. a4 cars arent that bad.
Old 09-25-2005, 01:45 AM
frkkevin's Avatar
That is what I was thinking. Especially in the heavy traffic I tend to get stuck in. But for some reason a 6 speed standard just calls my name. A plus to the standard is I could squeeze a bit better gas mileage out of the car. But anything sure beats my car I drive now. It only gets 12mpg hwy and 10mpg city. Eventually I'd be doing some engine mods. One of the three to start with. LS2 conversion, Turbo, or Supercharged. With the extra hp and torque which transmission would be the best bet? I know the lower mileage motor would be a better start for making a higher output motor.
Old 09-25-2005, 02:54 AM
71camaro's Avatar
A beefed up auto with a big stall would be real bad ***. and could handle most of what u throw at it
Old 09-25-2005, 05:05 AM
Old Drag Racer
Smokinstorm's Avatar
The manual tranny car will probably squeeze 3-4 more miles out of a gallon of gas. However, if you drag race often, you'll love the ease at which the auto will let you get down the track. Add a stall, some gears and some sticky tires and just head out and mash the gas to a low 13/high 12 second pass. Those times can also be achieved with the manual but it just takes more work, driving wise. Also, the lower mileage car is definitely the better one to start modding and keep.
Old 09-25-2005, 08:18 AM
4mula's Avatar
with just a stall, lid, catback and nittos i was doing mid 12s all day
Old 09-25-2005, 12:38 PM
CrabhartLS1's Avatar
I'd go with the A4 if it had less mileage. Sure you don't get that manual fun factor, but you can certainly make an auto more fun, and with a stall, even better than a manual as far as ETs are concerned.
Plus A4s are easier on the rear, something the M6 guys are capable of breaking stock.
Old 09-25-2005, 03:30 PM
99midnightZ's Avatar
what is a good stall to go with? if you had 3:73 gears on a a4
Old 09-25-2005, 05:55 PM
71camaro's Avatar
3600, yank, tci, fuddle.....
Old 09-25-2005, 06:30 PM
vig....
Old 09-25-2005, 08:38 PM
thunder95ta's Avatar
Is the 3600 stall still good for gas mileage or does it affect it at all. Is a 2600 stall good for performance and every day driving?
Old 09-25-2005, 10:36 PM
Formula_X's Avatar
The automatic A4 transmission in the late model firebird/camaro is great for an automatic, it shifts fast, smooth in regular driving, and has that hard M/T feel under heavy throttle. Go auto, especially considering the mileage difference.
Old 09-25-2005, 11:32 PM
your first question depends on if the stall has a lockup, and what speed it's set to. the stock TC will lock up at 40mph and low rpm, a lot of aftermarket ones don't. but this is pretty much set in the tune. Regardless of the lockup in town tho, they lock up on the highway just fine.
Short answer: you'll notice a drop in mileage in city driving, but highway mileage will stay the same. "streetability" is different for everyone, but i imagine a 3600 would be very streetable, given that there's a lot of daily drivers around with 4k stalls. but that's pushing it.
a 2600 stall is practically useless, anything lower than a 3k i would not recommend. 3200+ is usually a good idea.
Old 09-26-2005, 12:01 AM
SmokingWS6's Avatar
I'd go for the low miles a4. Thats how I ended up with my car, it was practically new which is why i chose it, even with the auto.
Old 09-26-2005, 12:05 PM
ponyeater01LS1's Avatar
i have 3600 fuddle and its bad azz fast
Quick Reply: Automatic vs 6 speed Standard
