Transmission pan leak
Old 09-28-2005, 10:07 PM
Torcque's Avatar
Default Transmission pan leak
Ok,
I have a 700R4 in my '85 Impala. The transmission pan has had an annoying one drop leak for about a month. The old gasket was obviously shot so I decided to replace it. Unbolted the pan, drained the fluid, cleaned off all the old gasket material and put the new gasket on (looks like it's made of rubber. Got it from O'Reilly autoparts) and bolted the pan back on. Refilled with 4 quarts of fluid. two days later, it's leaking again. Drop here. Drop there. Figured I didn't tighten the bolts up enough, so torqued them some more. Still leaks. Put in some Prestone ATF Stop leak. Checked it tonight. Still leaks. Looked underneath and can see the edge of the gasket is wet with fluid. I checked the fluid level after I got home (30 minute drive) and it isn't overfilled, so that's not it. The pan didn't look damaged or warped. My next option is either a new OEM style Steel pan (with drain plug) or a B&M Chrome Steel Deep Pan (with drain plug)I found at Pepboys. With either pan, the drain plug will make future fluid changes easier. The Deep pan comes with a gasket that is probably of a higher quality than the one I got from O'Reilly. I've heard that the deep pan increases cooling ability. Assuming I replace the pan, is the deep pan better? Any thoughts on my pan leak? It's leaking on the driver's side back edge. Nowhere else.
Old 09-29-2005, 11:11 AM
Torcque's Avatar
Bump. Anyone?
Old 09-29-2005, 11:43 AM
Ragtop 99's Avatar
if you replace the pan, go with an aftermarket unit with extra capacity and cooling capability. Dearle makes an inexpensive pan and TCI also has a nice pan.
