TH400 RMVB Questions
Ok I have a couple things I need to get straight:
1. With a Reverse manual valvebody, do I have to wire up the transbrake to even get into reverse? or can I leave it disconnected for the time being?
2. Downshifting: can I downshift the car at a low speed at all?
3. What all is involved in swapping out the rmvb to a forward manual setup? Is it as simple as just unbolting and putting the new one in?
1. i don't know
2. downshifting at low speeds is fine... as long as it's like, no more than i'd say... 15mph.
3. if you are talking about shifters..... no it's not that simple. you need a new valve body installed in the trans. if that is simple to you.... then yes, i'm pretty sure that's all that needs to be changed (shifter as well... der)
