Bad rattle ofter TC install
Old 10-06-2005, 08:29 AM
Joel_SS's Avatar
Default Bad rattle ofter TC install
http://members.torquecentral.com/joel/rattle.mpgright click save as
I cannot find this rattle. I have removed the console and checked everything. Nothing I can find is rattleing under the console. This rattle started after I got my TC installed.. I looked under the car and could not find anything either! It only happens around 60-70 MPH.. At lower speeds sometime you can hear it as well but it is not popping as quickly
Old 10-06-2005, 08:41 AM
GregWS6&z28's Avatar
is the video like 1 second long? cause thats all I got
Old 10-06-2005, 09:38 AM
Joel_SS's Avatar
no it is about 30 seconds long. Save it to disk before you play it. It will not stream it.
Old 10-07-2005, 09:55 AM
Joel_SS's Avatar
Little more info.. It seems to only do it around 2000 - 3000 rpm.. If I go faster it goes away.
Old 10-07-2005, 11:26 AM
camaronut502's Avatar
prolly not the same rattle but after i got my tc installed i noticed a rattling sound and it was a heat sheild and the shop just bent it back out of the way and i havent had a problem since.
--Matt
Old 10-09-2005, 12:34 PM
Joel_SS's Avatar
--Matt
I checked the heat shields and they seemed okay.. I will check them again..
Old 10-13-2005, 12:55 AM
Joel_SS's Avatar
Anyone else?
Old 10-14-2005, 10:52 AM
ponyeater01LS1's Avatar
me too bent the heat shields and put radiator hose on top of the y pipe and all sounds are gone. the hose will not melt either.
Old 10-17-2005, 09:49 PM
Joel_SS's Avatar
Cool I will check the radiator hose
Old 10-18-2005, 09:32 AM
BubaGumpShrimp's Avatar
i have a damn rattle that i can hear at 750rpm and again at 2,000 rpm. Cant hear it in any other rpm, does it in park and drive. Ill check the heat shield later today...
Old 10-18-2005, 08:09 PM
BrokenTA's Avatar
You might want to check your flexplate bolts as well. I torqued mine to the factory spec after I put in a TCI plate and a Stall. They were loose before I had it off the rack. I had to locktite and do about 100 foot pounds.
Old 10-18-2005, 11:07 PM
i heard that the tci flexplates had problems due to the powdercoating and the fact that the holes are for bigger bolts, the size only used by tci and their converters.
Old 10-20-2005, 11:42 AM
Joel_SS's Avatar
I am using the stock flex plate.
Old 10-20-2005, 10:05 PM
why did you say you put in a tci plate?
Old 11-07-2005, 02:42 PM
Joel_SS's Avatar
I did not, some other guy in this trhread did.
Any other ideas?
Old 11-26-2005, 11:28 AM
ShadowLightCSU's Avatar
I had a bit of a rattle going and it went away, but my guess is that the tranny cooler lines are touching somewhere.
Old 11-26-2005, 11:51 AM
Cheater's Avatar
Yea man make sure your bolts are tight
Old 11-26-2005, 12:06 PM
pwrtrip75's Avatar
did you by chance change the tranny mount when you put the converter in? I put one of these "Energy Suspension" Poly mounts in mine and it vibrated like hell....the bolts that went into it were too long and bottoming out inside the mount causing it to become sollid. A few washers and it it went aways.
Other than that.... rather than a rattle, that looks a like a bad vibration. If it only does it at certain RPMs something might be out of balance. converter?
Old 11-26-2005, 12:28 PM
MattZ28's Avatar
Maybe something rattling around in the inspection cover?
