very bad vibration
Old 10-06-2005, 11:56 PM
BLACKHAWK1998's Avatar
Default very bad vibration
I broken tailshaft housing on the dyno replaced it. installed a Spohn Adj Torque Arm Front Safety Loop now i have a very bad vibration above 90 mph.
Old 10-07-2005, 12:00 AM
one other thing i push it all they way to 120 try to drive out of it and the car acted like it was going to go boom. like the trans didnt want to go any faster the rpms went all the way up to the red line.
Old 10-07-2005, 08:43 AM
Pontiacerator
RevGTO's Avatar
Have you checked your tranny mount? Do you have a steel or aluminum driveshaft? Are you sure your tranny is shifting into 4th?
Old 10-07-2005, 03:22 PM
PERFECT Z28's Avatar
I just had the same problem, I'll finish my car tonight. I was told it might be vibrating because your output shaft could be bent...I hope this isn't the case for me too!
Old 10-07-2005, 05:21 PM
ramairws6's Avatar
Well if your like me you'll fix everything but what the problem is. I replaced almost everything possible but the transmission output shaft, and that is what ended up being the problem. It was bent just enough to cause a bad vibration.Let me know what you find out. Traver
Old 10-07-2005, 05:48 PM
1LoudTA's Avatar
yeah mine vibrates above 90 also...? info plz
Old 10-09-2005, 01:33 PM
How much did you pay for the output shaft?
How hard was it to replace?
Old 11-10-2005, 05:55 AM
ramairws6's Avatar
I bought the shaft used for $30.00. The bad part about it was the trans had to come apart. Traver
Old 11-10-2005, 02:55 PM
My friend is replacing the output shaft today...I hope nothing else is broken or bent. I am also installing a VIG 3200 to help me off the line.
Old 06-05-2006, 04:40 AM
ramairws6's Avatar
Well whats the verdict? Fix the problem? Let us know what you came up with. Traver
Old 06-05-2006, 09:59 PM
DrkPhx's Avatar
It sounds like the pinion angle may need to be adjusted.
Old 06-06-2006, 10:30 AM
fast01's Avatar
I just went through the same thing as well. Make sure you check the bushing in the rear of the case where the output shaft exits. I found that with mine the bushing was wiped out and spun inside the case thereby ruining the case itself. If the bushing spun you will not be able to install a new one and will need to replace the case.
Quick Reply: very bad vibration
