I will buy TransGo shift kit towmorow. Do u agree?
Old 10-09-2005, 06:57 PM
LS1SS4ever's Avatar
Question I will buy TransGo shift kit towmorow. Do u agree?
The car is daily driver and I will buy one like in this picture. Which level should I install one, two or three? Is it safe for the Trans?
Old 10-09-2005, 07:49 PM
jxaxsxoxn's Avatar
First read the instructions. It's not as easy as stage one, two, or three. The word stage isn't used.
You are going to have to select feed hole sizes in the seperator plate, different springs that go with certain valves, servos, etc.
You install the kit in the configuration that will make your transmission shift like you want it to, you might have the same exact vehicle, same kit as the next guy and the specifics of how the two kits were installed can be totally different.
When I installed my kit I did things to my transmission that aren't even in the instructions. These came from past experiences and professional suggestions.
Old 10-10-2005, 12:48 AM
Restricted User
Automatics's Avatar
When you get ready to do this, call me at 909 7951876, anytime past 11am PST.
Old 10-10-2005, 10:43 AM
LS1SS4ever's Avatar
How is the old TransGo shift kit that with blue and white color? Is it better than the above?
Old 10-10-2005, 10:51 AM
Tom's_03SVT's Avatar
i had the programmable one on my SS. its a great kit, i would recommend getting professionally installed.
Tom
Old 10-10-2005, 11:03 AM
AK's WS6's Avatar
I went with 1 washer per Pro built automatics. Mine is also pretty much a street machine.
Old 10-10-2005, 02:08 PM
BubaGumpShrimp's Avatar
i hope you have a programmer for after the install, you need to make changes to torque management..
Old 10-10-2005, 07:18 PM
LS1SS4ever's Avatar
Wink
I will tune it for all my mods + ported TB
Old 10-10-2005, 07:30 PM
ok if you have a programmer than go for it...
Old 10-11-2005, 05:59 PM
BLUE99T/A's Avatar
I installed the same one and I love the results. The 3 stages you're talkin about are the washers you put in at one point in the installation. I put all three in, I really didn't have a professional handy so I figured if 1 is good then 3 is better. Nothin bad has happened so far...
Old 10-11-2005, 08:40 PM
Red Heartbeat's Avatar
I thought stage three is a full manual valve body. The 4L60E-HD2 kit worked beautifully in my 2002 LS1 with all holes drilled as race mode and one shim.
Old 10-12-2005, 05:06 AM
LS1SS4ever's Avatar
I will go with 1 washer (for daily drive and street racing)
Old 10-13-2005, 04:36 AM
bud8fan's Avatar
1 washer is plenty for a daily driver that see's a little track time...
Old 10-13-2005, 02:13 PM
LS1SS4ever's Avatar
Exclamation
Think of buying this kit. What do you think about this kit?
Attached Thumbnails I will buy TransGo shift kit towmorow. Do u agree?-image-212-.jpg
Old 10-13-2005, 02:33 PM
AK's WS6's Avatar
That is the one I bought from Pro built automatics. I'd contact him for his "modded" version. There was also a high-rev spring kit included, but you'll have to get pretty deep into the trans, so I opted not to install it untill I need a re-build. Are you having a trans shop install it?? The guy that did mine charged me $75 with a new filter and no fluid and he wanted $150 if I wanted the high-rev spring kit installed with the rest of the kit.
Old 10-13-2005, 02:42 PM
LS1SS4ever's Avatar
Wink
No its bone stock
Old 10-13-2005, 02:59 PM
AK's WS6's Avatar
Originally Posted by LS1SS4ever
No its bone stock
I was refering to the shift kit install....
Old 10-13-2005, 03:07 PM
SteveC's Avatar
Location: Poway, Ca. where GOD and the sun always shines
I had the shift kit installed professionally with my Y3000 converter, and per the instructions they set it up with the #3 washer.
SteveC
Old 10-14-2005, 11:16 AM
GOGO's Avatar
Hey LS1SS4ever I a NIB TransGo shift kit that you originally posted. Its for sale if you are interested.
Old 10-15-2005, 09:28 AM
andy1h2004's Avatar
Hi Andy here;I Got a Newbie question for any that have the patience, I've been reading alot on the automatic trans, and learning somethings. . . I am in the process of rebuilding my 98 t/a's trans. for the 2nd time and do not want to go back into it; I want to make it stronger, it's a dialy driver that may see the track 1-2 a year (so never) with basic mods headers, exhaust, cold air intake, so any way my question is What's a shift kit. . .thanks. Also Steve C what's the diff. between your converter the Y3000 converter and a basic Stock one from the dearler. . .durability, power, etc?
