Is a 3400/2.1 stall too much for a stock 98 Z28 to handle?
Old 10-20-2005, 07:25 AM
ARCTICWHITE98Z28's Avatar
Default Is a 3400/2.1 stall too much for a stock 98 Z28 to handle?
Just wondering what everyone thinks about putting in a 3400/2.1 stall converter into my stock 98 Z28? I have 79,000 miles on it and it runs and shifts great. What exactly can a 4L60E handle when its stock with 79k? I mean is this much stall going to break parts? I will also be installing a tranny cooler at the same time. Thanks.
Old 10-20-2005, 08:22 AM
chrs1313's Avatar
no i think that sounds about right, i am getting a ss3600 with a 2.2 str, but if i get slicks or a drag radial with a 12 bolt, it is only a matter of time before the rear end goes out. Usually the trans are pretty strong but the rears end up blowing which then in turn takes out thr trans.
Old 10-20-2005, 08:36 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Go for it. You will be ok. And you will feel the difference.
Old 10-20-2005, 10:10 AM
Muerte_X's Avatar
I have a 3800 with a 2.7str, and mine's pretty much stock, people don't even know I have a converter until I tell them (if they even know what one is).
Your tranny should be fine, just make sure you don't forget to install that cooler.
Old 10-22-2005, 08:37 PM
Scotty-Z's Avatar
I've got a 3400 2.2 and it's amazing. Not too much at all.
