my 2002 Z-28 Transmission!!
Old 10-25-2005, 08:47 PM
GetIn&Go's Avatar
Default my 2002 Z-28 Transmission!!
Heys guys,
I just bought a 2002 Camaro Z-28 with an Automatic Transmission.19,000 miles on car.I bought ot sight unseen so when it finally arrived off the truck tonight I was so excited.When i drove it,the transmission holds 1st gear till about 4k rpm.I can get it to shift before that by slightly pulling off my foot from the gas pedal!Also when i am at 60mph i slam it down & it just comes out of gear & rpms go into orbit!!
Ok anything to look at before we declare it fried transmission?I have an older chev & when the vaccuum line off the transmission comes off it will react the same way!!!Ofcourse this is all electronically controlled!
Thanks a bunch
Old 10-25-2005, 09:48 PM
Pontiacerator
RevGTO's Avatar
You may just have a very high stall converter in the car. Does it actually go into neutral when you stomp it in 3rd, or does it just rev up quickly like a slipping clutch while in the lower gear? If the latter, you probably have an aftermarket converter. Did the previous owner say anything about a converter? One thing for sure, before getting into tranny internals, see what kind of converter is in there.
Old 10-25-2005, 09:50 PM
c0ncEpT's Avatar
hello 4200 stall?
Old 10-25-2005, 10:07 PM
GetIn&Go's Avatar
yeah i was thinking higher stall convertor also.I bought it from a dealer on ebay.Also the check engine light is on! No it definitly comes outta gear in 3rd.The motor revs past 8k & nothing in gear.funny thogh when it does shift it doesnt slip !!
Old 10-25-2005, 10:31 PM
Pontiacerator
RevGTO's Avatar
Be careful about revving that motor to 8k - or to 6k for that matter if it's unloaded - or you may be getting into the motor before the trans.
Old 10-26-2005, 08:26 PM
GetIn&Go's Avatar
yep confirmed tranny blown! Wont shift into 2nd gear cause it aint there anymore!Thats why it revs forever is because its downshifting to second & no one home!My trans guy told me he could rebuild mine & make it for the track with a 2800 stall coverter for around 2800 bucks installed.I didnt go into all the details but from what i hear this guy really knows his transmissions.
Old 10-27-2005, 09:40 AM
Ragtop 99's Avatar
That's a lot of coin. Make sure you get a good rebuild with upgrades. Also you might consider other converters. 2800 is pretty low stall and there are some good, proven converters available that I would buy over a no name unit.
Old 10-27-2005, 10:31 AM
99ssleeper's Avatar
go with atleast a 3500 stall.
do a search...2800 stall is tiny, you'd regret it.
