new best stock motor fuddle 4K!!!
Old 10-30-2005, 02:37 PM
spec_j's Avatar
Default new best stock motor fuddle 4K!!!
1.59 60'
12.2
108
1.59 on stock motor w/ exhaust, stock pulley, stock LS1 intake, etc.
mods are...
LT's, ORY, CB
lid
Fuddle 4K 2.5
275/50/15 MT DR's
big thanks to John @ fuddle for the advice, and Fuddle Racing Converters for a SICK, wicked converter.
Old 10-30-2005, 02:55 PM
eric01ss's Avatar
hell yeah sounds good man
Old 10-30-2005, 04:23 PM
s346k's Avatar
i had a 1.70 60' with my fuddle 4k. but i can only footbrake mine to 3k in 1st gear before it will start spinning the tires, does yours do this, too? my 1/8 mile went from 8.73 to 8.18. the car never has been a "strong" runner, but is fairly consistent.
i was on 255/50-16 bfg drag radials, 16 psi. dead hook, no spin, launch from ~2,800.
Old 10-30-2005, 08:28 PM
Hennytime's Avatar
i would worry about that rear end on those tires, but good times, give me hope for when i get my hotcam stalled
Old 10-30-2005, 10:40 PM
spec_j's Avatar
I can stall mine to 3300 with the M/T DR's, but my car launches best at 2500-2600.
I yank the stock 16's up front with it. at 3000 my stock suspension binded, then unloaded hard causing the car to bounce and spin, that that caused my stock PHR to bend and break a hanger on the CB and put a hole in the tail pipe.
first time ever running the car with that fuddle 4K in 90 degrees, 90% hum. and 2100 DA was 1.65 all day.
the 1.59-1.60's where a couple days ago w/ 70 degree, 40% and about 600 DA
i hope that in cooler weather the fuddle will put me in 11.99 stock cam, etc.
Old 10-30-2005, 10:55 PM
BubaGumpShrimp's Avatar
you guys suck, i havent had the time to hit the track yet with my fuddle 3,800.. specj what did your car run before the converter(did you have a stock converter before this one). Nice times by the way...looking forward to hitting the track.
Old 10-30-2005, 10:58 PM
gator's 99TA's Avatar
good conveter. i went 10s on mine with radial tires
Old 10-30-2005, 11:25 PM
spec_j's Avatar
best time ever was w/ a lid, cutout, 16" nitto's and stock stall
12.8, but the average is 13.1 or so
with with good tires, the fuddle 4K, and full exhaust thru a Magnaflow is 12.2
spec_j's Avatar
I can vouch for that
Old 10-31-2005, 09:23 AM
Ragtop 99's Avatar
1.5x 60' is a very nice time. A little cold weather and a 100lbs of weight reduction and you'll see 11s.
Old 11-01-2005, 11:05 PM
spec_j's Avatar
im looking into some suspension mods right now, hoping that with those and this kickass converter i will be able to get into the 11.8x range on the motor, and like gator said in another thread, these verters like N2O, so i might use the 75 shot i have and see what it will do
Old 11-02-2005, 08:05 AM
Ragtop 99's Avatar
If you are dead hooking and cutting good 60' times, I doubt you'll see much gain from suspension mods.
Old 11-02-2005, 08:41 AM
MNR-0's Avatar
That's one of the best times I have heard from a converter - stock. How light was the car?
Old 11-02-2005, 09:54 AM
i have watched the car launch and there is more to be gained. not a HUGE amount but some left. he is still slightly hazing the tires through the 60' and slightly wheelhoping it too. LCA and relocation brakets will take care of that.
we have had guys go 1.49 60' on completely stock suspension with good converter and spray at our track. its sick.
Old 11-02-2005, 10:47 AM
eric01ss's Avatar
is that at full wieght and is the car tuned if so that freaking moving man pull some weight and lower those ets
Old 11-02-2005, 12:50 PM
spec_j's Avatar
yes its 100% full wieght... its tuned for AFR, and smoothed out timing. Gator, didnt even realize that it is hazing the tires, couldnt feel it? damn... good eye man! thanks much !!
glad to know that I can still get better!
Old 11-02-2005, 06:32 PM
DevonsZ's Avatar
Good times Spec
Old 11-02-2005, 11:15 PM
SLIKWS6's Avatar
Congratulations, Im hoping a converter will put me into the high twelves here in Colorado with a bolt on only car. Other guys around here are running cams and superchargers and only running 12s or 13s, so your times really make me look forward to next year.
Old 11-03-2005, 12:34 PM
Joe Spinners's Avatar
i'll be heading out this friday to the local track, what are you fuddle guys stalling up to at the line...when i first ran my fuddle i got a 1.77 60ft but only flashing it from about 1400 or so, i wanna know what you guys are launching at
Old 11-03-2005, 03:11 PM
spec_j's Avatar
if you have really sticky tires that can hold a big hit, I found the best to be 2500-2600 rpm then flashing it is best for stock suspension.
