trans line thread size
getting ready to run trans lines to trans cooler and need thread size at trans to get adapter to -6 AN. any help would be appreciated so I don't spend more time running around then to do the job.(already blew rubber hose once not again)
I spliced my tranny cooler into the return line out of radiator (fluid passess thru radiator first) ..... I used earls aluminum plumbing parts, the fittings for 5/16 tubing worked fine to make splices into tranny lines.
