TCI SSF Question
Your wording is a bit confusing, but I'm guessing you are asking if a stall with a shift kit are only used for racing and the answer in no!. If the shift kit is setup properly with street/strip in mind the shifts at part throttle can be fairly light and be nine and firm/quick at WOT. That is how mine is setup per Pro built automatics (<search) "modded" kit and suggestions.
Pontiacerator
