any body real good with automatics
Old 11-06-2005, 01:23 PM
ta12sec's Avatar
Default any body real good with automatics
turbo 350 trans just did clutchs steels and seals and a new pump. reason for rebuild pump ate it self. Put it back together and in the truck and now I have a nose from the trans. Noise is only there when in gear while at a stop goes away in park and neutral and once im moving sounds like a lite metal on metal shushing sound .
So I'm thinking the convertor has to be bad, since when your stopped and in gear everything in the trans should be stoped just convertor spining aaround the stator/turbine, anybody else have an opinion?
