Tilting the 4L60E to remove servo
Old 11-07-2005, 10:45 AM
LS1-450's Avatar
Default Tilting the 4L60E to remove servo
Can I lower (tilt) the transmission with the drive shaft connected? I want to remove the servo from the side of the transmission & will have to lower the transmission to do so. Can I remove the tranny mount & tilt it down safely with the drive shaft connected or will this damage the rear housing seal? It needs to tilt down about 5 or 6". Thank-you
Old 11-07-2005, 12:48 PM
LS1Tech Sponsor
hellbents10's Avatar
How much room do you have. If you have 3-4" you can dissasemble the assembly as you pull the servos out. I have to do this on S-10's all the time.
Old 11-07-2005, 03:30 PM
LS1-450's Avatar
hellbents10,
Thanks for the input. Only had about 1.75" before hitting the side of the tunnel. I went ahead & tilted the transmission low enough to wriggle the servo's & then the shaft out. Doesn't seem like there was any damage to the rear seal.
Wish I had known that the blue spring wasn't used when changing the intermediate servo with the 4th gear servo. I struggled with that spring for an hour before calling the manufacturer of the kit & finding out it's not used with that combination. Anyway, it's done.
Thanks again for responding.
Quick Reply: Tilting the 4L60E to remove servo
