Tailshaft info needed...
Old 11-13-2005, 10:53 PM
Restricted User
CAT3's Avatar
Default Tailshaft info needed...
I swapped from my old 4L60E to a TH350 ( and loving it so far). But, always something right. I dont have the speedo hooked up and do not want to do the VSS to WSS. I want to know if the stock tailshaft with reluctor wheel will fit the TH350 or not. I contacted Rossler, who built the trans, for the tailshaft adapter stuff, but forgot to ask. I still have the stock trans, as it has a billet servo and this that and the other stuff in it, but blown clutches and steels. So, if the tails can be swapped, then I will do that.
Charlie
Old 11-14-2005, 12:40 AM
jxaxsxoxn's Avatar
If your th350 has a 9" tail you can put the f-body tail on it using a spacer between the case and tail housing. I forgot who makes the spacer.
Old 11-14-2005, 01:22 AM
Restricted User
CAT3's Avatar
Damn it, sounds like another dead end search. Jason, if you happen to find out, please post for me. The other option is I buy the Rossler tailshaft w/ reluctor $250. I do have the 9" tailshaft also.
Old 11-14-2005, 06:04 AM
jxaxsxoxn's Avatar
Someone told me rossler makes the spacer. Doesn't seem like it would be too expensive, you just put it on and use your 4L60E tailhousing and everything else.
Old 11-14-2005, 11:50 PM
Restricted User
CAT3's Avatar
Great if I could, then I could use the stock exhaust hangars for my Corsa thats in route! Will be calling tomorrow.
Old 11-15-2005, 05:24 AM
jxaxsxoxn's Avatar
Heres a picture of it. Have no idea where I got this from.
Old 09-24-2009, 02:12 AM
Dirty 30's Avatar
I had a spacer on a th350 back in '04 but never found out any info on it. Anyone? Im trying to keep my ABS and speedo working.
Is it this one?
http://www.teckpak-fitzall.com/datasheets/7q-35b.pdf
or
http://advanceadapters.com/product/2322/50-0405.html
or
http://advanceadapters.com/product/2...M-VSS-Kit.html
I found a pic of the th350 i used to have. You can barely see it in the lower right hand corner...
