th350 12bolt no abs- i need the speedometer!
7 Second Club
what can i do to make my speedometer to work with a th350, 12bolt with no abs...
the car was a 2.73, abs, and ASR(traction control).
help please...
ive read the sticky about it but it doesnt give help to me
help please...
LS1TECH Sponsor
Look at your old tailshaft. On the Drivers side there should be a sensor. If it is not on the TH350 tailshaft you will need to update the output shaft for the VSS ring and put the sensor in the TH350 tailshaft.
That's the simple explanation.
front wheel sensor works fine, just have to fool around with some numbers in the speedo calibration to get it close. All you do is take the two wires that went to original speedo sensor in the trans and hook them up to the two wires from the right front wheel sensor by the PCM. You can follow the wires right up from the wheel bearing, polarity doesnt matter.
Originally Posted by ty_ty13
explain how this works?
and to get it right on the $$$ use a programer or tuning software to set your gear ratio at 2.76 (if you used to have a M6) and then MEASURE your front tire circumferrence and put that in as well. don't just assume the circumference from what peoiple on here say actually measure it all tires are different.
