Do you need to remove the VB to install the vac mod kit?
Old 11-20-2005, 06:50 PM
jxaxsxoxn's Avatar
Default Do you need to remove the VB to install the vac mod kit?
I'm still waiting for my vac mod kit to get here.
Already changed the sungear shell, 3-4 clutches, 3-4 springs, band, drilled the spacer plate holes, etc.
I want to torque the vb down before I forget
The only thing I see is the clip that holds the actuator valve in is removed from the case side.
So to install this does the actuator valve or vb need to come off? Or can I go ahead and torque the VB down.
Leaving the accumulator housing off of course, i ordered an aluminum piston for that too thats not here yet either.
Oh yea speaking of those plastic pistons, where can I find a small pin aluminum forward accumulator piston?
Old 11-20-2005, 07:27 PM
TeamTripp's Avatar
You don't need to remove the Valvebody, just the accumulator housing and PC Solenoid. I have the pistons you need in stock, send me a PM if interested.
Old 11-23-2005, 09:55 AM
Cheater's Avatar
hey teamtripp you still have some pistons
Old 11-23-2005, 08:15 PM
TeamTripp's Avatar
PM Sent.
