Shift kit help
Old 11-22-2005, 04:38 PM
6.0caddy's Avatar
Default Shift kit help
I have a 4l60e and need a good shift kit. I am think B&M? any input? i got a 99 silverado thanx
Old 11-22-2005, 07:46 PM
GT Griller's Avatar
I was actually gonna post a question about this. I see everyone go with Transgo, but i have seen a B&M shiftkit on jegs for like 60 bucks. How come no one goes with that one? Is it not any good?
Old 11-22-2005, 08:51 PM
BubaGumpShrimp's Avatar
trans go kit is the way to go. It changes more things then the b and m one..
Old 11-22-2005, 09:08 PM
Go Faster's Avatar
I vote for TransGo!
Old 11-22-2005, 10:38 PM
LS1Tech Sponsor
hellbents10's Avatar
Trans go or Superior with a boost valve. The B&M one is not worth dropping the pan for.
Old 11-23-2005, 10:39 AM
6.0caddy's Avatar
thanx for the help, now where is the cheapest place to buy one?
Old 11-23-2005, 02:10 PM
they are usually 110 almost anywhere like summit,jeggs, or any off the sponsors on this board.. I would suggest you check out pro built automatics modified trans go kit which takes the kit a step further for the trans in our cars.. do a search for the user name probuiltautomatics..
Old 11-25-2005, 02:56 AM
Nocturnal SS's Avatar
Put your money on the Trans go.
Old 11-25-2005, 07:31 AM
jxaxsxoxn's Avatar
Heres the cheapest price you will find.
Old 11-26-2005, 05:53 AM
Restricted User
Automatics's Avatar
If you are looking for the latest in updates & modifications, go to http://www.700r4l60e.com/store/custo...&cat=28&page=1 This will give you everything you need to make one of these units last, and I set it up to match your engine/torque converter/rear end gear ratio, & how you drive. Give me a call at 909 7951876 anytime past 11am PST, and i will be glad to answer any questions you might have.
