Can i fit a th350 in a 01 Ls1 camaro and how?
Old 11-23-2005, 10:39 AM
nhra_crazy's Avatar
Default Can i fit a th350 in a 01 Ls1 camaro and how?
I am wandering if I can put a th350 in my Ls1 car and what mods I need to do to make it work.....
Old 11-23-2005, 11:20 AM
LS1TECH Sponsor
Steve Burger's Avatar
Yep I just did this. Yu will need:
Th350 9" tail shaft
VSS conversion on tail shaft
Converter built for TH350 with LS1 snout
Flex Plate recommend TCI
Dip stick tube rocommend Lokar 36"
Cross member recommend BMR
Shifter I love the Cheetah
Stock drive shaft will work
Could be other stuff I missed. But I think this is complete.
A4 or M6?
Old 11-25-2005, 10:07 AM
LS1TECH Sponsor
Jonathan@Tick's Avatar
I should probably search for this first, but I am planning on doing the same swap in an m6 car. What is involved to make the speed sensor work? Also, will an old style torque converter work on an LS1? And what about the detent cable, does it need to be hooked up?
