B&M 28,000 GVW fittings.
I've bought a B&M 28,000 GVW oil cooler to keep the tranny temps down. It ships with no fittings. Anybody happen to know the exact type fittings I need to look for? They're 1/2" but is there a specific name for the type of fitting and what size is the hose connector side if the 1/2" fitting? Hopefully it will mount like the 19,000> between the radiator and condensor. Anybody know?
Moderator
From Jeg's:
NOTE:
(1) Racing model doesn’t include installation components and has female 1/2 NPT fittings. Can also be used as an engine oil cooler. Note: GVW stands for Gross Vehicle Weight (total loaded weight of vehicle including trailers or towed vehicles).
(2) A compact but highly efficient version of the race cooler. Does not include installation kit.
I think maybe you'd want some 1/2" NPT male to flare
fitting females, and do it all in hard line. But you can
probably get by with barb & hose. I once dated a
woman named Barb. Heh.
NOTE:
Moderator
NPT to hose barb, you can get at Home Depot;
NPT to flare probably at any AutoZone or NAPA
type parts store. Just depends on what you want
the in-between plumbing to be made of, rubber
or hard line.
or hard line.
