Big problems!! Help!
Alright, so I'm working with a friend of mine to swap out a torque converter on another buddy's car, and we've hit a what might be a big problem.
As we're trying to loosen the torque converter bolts, they start to strip. One is almost completely stripped, and another started to round out before I stopped and is now rounded a little. The third one is untouched.
This is the first time either of us has had this problem with these bolts. We've worked with them before, and they were a pain, but they still came out. They aren't notmal hex head bolts, they are rounded on the outside and have a hex head...thing...in the middle (see picture). The picture is of a bolt taken from another car, but it's the same kind we're dealing with.
What can we do? I'm supposed to have this trans out by now to have other work done to it!
Thanks for any help you can give.
I have had to slide the tranny out of some car with the convertor still on the fly wheel!Then I put a good pair of vise grips on the outside and the hex dit to! Mine came lose!If there rounded have ya tried beating the next bigger size in the hole of the messed up ones!Good luck maybe ya can get it going!I have standard and metric ones too can't remember wich one fit the tightest!
The fly wheel doesn't come off it stays on the motor with the convertor all that holds the convertor is those bolts so if you take all the bell housing bolts lose it should come back some of them are a pain to get to come loose because the dial pins in the block rust so you have to shake the crap out of the tranny I usually get get a big pry bar and find a good spot to work it lose! IOts a tight fit!
Originally Posted by 2xLS1
Had that happen once. Used a torch on the bolt heads and got them cherry red. Let them cool a bit and they broke loose easily. We ended up replacing the flex plate though as we were worried about it cracking where the heat blued it.
