transgo install done
Old 01-02-2006, 10:33 PM
98Ztwentyeight's Avatar
Default transgo install done
my transgo install is done finally!! It takes right around 9 hours
in the driveway with jack stands with a few breaks in between and my tools
are not currently organised. I think if you had your tools in order ,had no
interuptions,no 50mph oklahoma winds and a clean area to work in, it would
take right around 5-6 hours in your driveway..
I was going to do a write up for this but I think the included instructions are
actually fine! they make sense and the video is for a older version of the
4l60e "basics still apply" the tape says stop and do what your instructions
say...just ignore the tape from there on for a bit and you will be fine !
this write up might help someone! its for a B&M kit but it gives you the general
idea of where things are that the transgo kit doesnt get into. "on the video
or instructions." all the tools needed still applies! dont forget the vaseline!
http://www.fullsizechevy.com/forums/...d.php?t=114807
Its a funny thing to walk into walgreens and buy a tub of vaseline
lol you get some weird looks from the checkout people! but yah need it to
keep the check ***** inplace or trans gel if yah have access to some
my car shifts harder now at part and full throttle and goes into gear with a
thump now and one thing weird happened though.
at 70 mph with tc lockup applied I used to be at 2350 rpms now im at 2100
rpms!?!?! both rpms were with the same tci 3500 stall convertor I wonder if I
was starting to slip a little?!?! maybe more pressure is applied or the correct
pressure to be applied is present now...
Old 01-03-2006, 04:59 AM
99whitews6's Avatar
Looking at that write-up the install doesnt look that bad, but I will be doing the work with the tranny out of the vehicle and the tranny flipped up side down. Won't all the check ***** fall out when I remove the valve body?
Old 01-03-2006, 11:41 AM
Default check *****
they sure will!
fallout like madd! you got the trans upside down so they WILL...
UNLESS you take off the bracket that hold down the seperator plate
and bring up the sperator plate with the valve body!!
then yah only have 1 check ball to worry about!!
Old 01-03-2006, 12:35 PM
99whitews6's Avatar
So why does everyone say that it is easier to do the Transgo install with the tranny out of the car? I might as well wait until I put it back into the car before I do the install!!
Old 01-03-2006, 05:10 PM
jxaxsxoxn's Avatar
You need to work on the trans when it's level if it's out. You can mount it to an engine stand.
Some say it's easier to install out of the car I guess because with it in the car you have transmission fluid constantly dripping out of it and it usually gets everywhere, it runs down your arms, get in your hair, etc.
Old 01-03-2006, 05:46 PM
99whitews6's Avatar
So, is there any way to remove the VB(while tranny is on its back) without loosing the check *****?
Old 01-03-2006, 07:31 PM
jxaxsxoxn's Avatar
Just make a sturdy fixture that holds the trans level. Maybe out of 2x6 wood.
I've done it but on an engine stand, and put the vb back on with no transgel or anything holding the ***** in place.
