tranny code...
Old 01-04-2006, 11:13 AM
s346k's Avatar
Default tranny code...
1-2 shift solonoid stuck open/off?
the car shifts perfectly fine? wtf? never had a second's worth of trouble out of the transmisssion, yet.
Old 01-04-2006, 02:10 PM
BubaGumpShrimp's Avatar
did you just put a converter in
Old 01-05-2006, 07:15 AM
s346k's Avatar
been in for 3k.
Old 01-05-2006, 08:16 AM
JakeY2KZ's Avatar
I've seen that code thrown in my car once after my rebuilt tranny went in. I was told not to worry about it. Since then it's never came back and the tranny is still shifting fine. I'd just keep an eye out on your temps and fluid level just to be safe.
Old 01-05-2006, 10:14 AM
TeamTripp's Avatar
Originally Posted by s346k
been in for 3k.
How many times have you "romped" on it since the converter? That code sets when the RPM doesn't drop below a certain threshold after the 1-2 shift. A high stall converter keeps the RPM above that threshold, setting theh code. Most people with converters above 3500± have this code turned off in the PCM.
Old 01-05-2006, 01:02 PM
s346k's Avatar
A LOT. it still shifts perfectly fine.
