why the rpm limit on stock 4l80e
That is just GM recommendation for max rpms, just like the 4L60E has a max rpm of 6100 rpms. That doesn't mean that it can not spin higher, my 2002 1500HD (now) has a redline of 5800 rpms and shift (at WOT) at 5600 rpms. This (OE max RPM) applies to factory stock vehicles only, with factory stock power.
Moderator
I know when the 4L65 came out with its 5-pinion
planetary they recommended it be shifted lower,
some deal about oiling differences (less lubrication
up in there). This may be the same deal, maybe
GM didn't foresee this grunt-duty trans being put
behind screamer motors (forward-thinking as they
are).
are).
Restricted User
THere's a few people on here spinning the 65's to over 7000 rpm. I know their transmissions are doing very well and have seen them come off the line with 4000+ stall yank converters in them.
