What stall / str for 400 turbo?
Old 01-14-2006, 09:45 PM
N2RACINGLS1's's Avatar
Default What stall / str for 400 turbo?
car 3,630lb with driver, 400 turbo with manual valve body, 2:48 first gear, stock motor with headers and underdrive pulley max 6,200 RPM, 330 hp 350 tq NA & 380 hp 420 tq on the gas, 75 hp dry NOS, 3.5" alum. driveshaft, 9" housing iron center section, 3:70 gear, full spool ,35 spline axles, good suspension items added, 26X11.5X15 ET streets on 15X10 weld wheels.
I would like to get your opinions on what stall and str you would use. 25% street driven and 75% drag race.
Thanks
Old 01-15-2006, 01:48 AM
1badA3Z's Avatar
i run a 4000 in mine but i have more motor than u do and alot more gear,i wuld say a good 3500 converter wuld be good,jmo tho
Old 01-15-2006, 03:51 PM
I was looking to get some opinions from you guys! I am thinking at least a 3600 to 3800 with a 2.5 str.
Old 01-15-2006, 05:36 PM
1badA3Z's Avatar
yea that sounds good,really depends on what u want and how big
