need ls1 edit trans file
Ok im having problems with my trans shifting .I lowered the rpm and the speeds and still blipping the limiter on the 1/2 shift .The only thing thats weird is the performance shift tables are all at 225 on every value . The normal shift has values as in speeds but should the performance table be the same ? I need to fix this as im going racing my old trans shifted fine 1/2 but hit the limiter 2/3 when i took it apart its mint no damage so it definately electrical problem . New trans ,valve body, vacum modulation it shifts if i manually shift it .
Moderator
The Performance table is not active on an F-body.
Only trucks and other vehicles with a Tow/Haul or
similar button. Just use the Normal tables.
Check your fluid level, too low can make it shift crazy
slow, and slip.
slow, and slip.
