LS1 to 350 torque convertor hub/spacer
I'm looking for the torque convertor spacer hub for the LS1 to 350 turbo conversion. I found this part number in the search. B & M pn- 2801054-19.
B & M says this is not a good part number. Do you know the correct part number for the torque convertor hub spacer. I'm trying to bolt an LS1 up to a turbo 350. I have a 98 flexplate and a turbo 350 convertor.
Any ideas?
Thanks,
Bill
Any ideas?
Thanks,
Bill
if it is the stock style flexplate, i have one that would not work on my car from Raptor. it would not work with my TCI flexplate, but till work wit the stock thickness flexplates, or atleast would work with the stock flexplate out of an 02 T/A if the holes were drilled a little differently. it is a part number LS1-700 if i am not mistaken
I have the stock 98 flexplate and the torque convertor lines up nice but the hub is about 3/4" away from the crank. Does this spacer go between the crank/flexplate or on the trans side of the flexplate? If it goes on the trans side it will work? PM me with price.
Thanks,
Bill
Thanks,
Bill
it goes on the side were the starter won't be affected by it , remember you cannot move the starter closer to the flex plate , so flex plate stays close to crank. answer, yes. you can't have spacer on crank side otherwise you will not be able to start the car.
