guys w/ prothane tras. mount...
Old 01-22-2006, 04:42 PM
s346k's Avatar
Default guys w/ prothane tras. mount...
ok, so i just installed my prothane poly trans. mount. installation was easy, yada yada....
now i have wicked vibration. is it just because it's a solid mount? my stock rubber one was splitting, due to my shift kit i assume. the vibration is only noticeable when the converter is not locked...once it locks, it gets pretty smooth. with the stock mount, the car was SILKY SMOOTH when stalling and after lockup. no vibration whatsoever.
has this happened to anyone else?
Old 01-22-2006, 06:44 PM
BlackHawk T/A's Avatar
Prothane isn't solid...it's Polyurethane...
I can't comment but I do plan on doing that when my tranny is out before the new one goes in, simply to prevent breaking the stock one...i'll keep an eye on this thread.
Old 01-22-2006, 07:27 PM
spanky_55amg's Avatar
if you put poly mount(s) you will notice more vibration. put a stocker back on if you dont like it. and the stock one prob started splitting do to it been worn...
Old 01-23-2006, 09:40 AM
s346k's Avatar
yeah, i know it's poly...and i assumed it would transfer more vibration, but damn.
i put the shift kit in @ 45k (had the car for a week). i inspected the stock mount at that time, and it was perfect. i had to drop the crossmember and pry the tranny over during part of the shift kit installation, but anyway..
now the stock mount has very noticable tears along where the rubber itself meets the metal bracket, near the bolt holes. after changing mounts i have no more clunking with light throttle gear shifts, but all of the plastic in the interior (console..) squeaks now like a mfer. the car used to be SO quiet and smooth inside
i won't put the stock mount back in as it took literally 3 passes with a hard launch and hook between 1-2 to tear the old one up, car isn't daily driven, and after i do my headers/true dual setup, i can then pass the vibration off as my exhaust
Old 01-24-2006, 12:11 AM
2kta--89formula's Avatar
Get used to it......although, over time the vibration seems to have lessened to a degree <that, or maybe I've gotten used to it, lol!>
Old 01-24-2006, 05:54 AM
speedo's Avatar
Yep what they said.... I think if you put a stocker back in you will be like what the heck happened to the torque. My friend did the same thing said to much vibration blah blah blah and then got a stocker put it in, took it on a test drive came back and put the poly back in.
Good luck
Old 01-24-2006, 07:25 AM
JB00SS's Avatar
Same here! It does seem to lessen and I have gotten used to it. I wont go back it really makes the car feel more solid.
Old 01-24-2006, 07:49 PM
2001WS6Vert's Avatar
I had a poly mount and couldn't stand the vibration so I put a stock mount back on. Because of the power the stock mount was ripping. I bought the BMR crossmember that relocates the torque arm from the trans. to the crossmember. This helped allieviate the upward pressure on the trans. mount. I also modified the torque arm mount to accept the stock rubber mount. You can keep the stock mount intact if you do this and the car will stay civilized feeling.
Old 01-24-2006, 08:50 PM
MiaSSmaro98's Avatar
damn i hate the poly tranny bushing.i have a 98 ss convertible a4 and use to be smooth as a baby skin rebuilt the tranny the shop put a poly mount for the shift kit and damn vibration came alive but its true it does clam down after a while.droven like 1800 miles and is not as rough no more but nothing like the rubber bushing
Old 01-25-2006, 10:00 AM
Dustin 98TA's Avatar
Grind the two rubber bumps off the mount, and install it without the preload plate. It dosn't eliminate the vibration, but it sure does help a lot.
Old 01-27-2006, 01:57 PM
GrahamHill's Avatar
That's why they use rubber mounts/bushings from the factory.
My '97 has the stiff bushings from the trans, t/a, control arms, and panhard rod too. It give a "race car" feel, lol. And it makes the car just generall louder. Anything you got going on in the drivetrain you will now hear.
Old 01-27-2006, 02:57 PM
good tip dustin but is it safe?
Old 01-28-2006, 11:54 AM
I could see how the metal plate would be the culprit but...it has to be there for a reason?
Old 01-28-2006, 01:46 PM
doehmer's Avatar
just installed a new ( rebuilt) trans with a poly mount. also installed a higher converter. took it out for a test drive and studder shake shake. thought bit might be the converter. glad i came across this thread, cause i would be chasing that shake for awile thanks
Old 01-29-2006, 08:51 AM
SSPEEDY's Avatar
Vibration with a poly mount is normal due to the harder material. I noticed on my car it took a good 1k miles or so to "break in". Seems a little less now but will never go away completely. Necessary evil.
Old 01-30-2006, 10:50 PM
Ive had mine on for 2 yrs with no problems whatsoever. Before that I went through 2 stock mounts.
Just make sure and loctite the bolts, I had it back out once and thought I had another broken mount.
Old 01-31-2006, 02:50 AM
Restricted User
CAT3's Avatar
Yep, have the same vibes from the Poly trans mount. No difference after putting in poly motor mounts. I took the plate out, didnt grind the two nubs though, no need to really. Yes its safe. And yes, it does seem to relax some after a few thousand miles. GL,
Charlie
Old 12-17-2010, 01:34 PM
tittan1500's Avatar
Just use a stock mount my prothane made my car feel like a jack hammer
Old 12-17-2010, 02:03 PM
Nitrojunkie's Avatar
Holy 5 year old thread bump batman..... better cut that out befor you get banned...
